Limiting chart to top results
Topic Labels: Extensions
2121 2
Tim_Reaper
I’ve currently got a bar graph for amount of plays a track has in a recording, but there’s 1000s of tracks in the grid view data and I want to limit the graph to only show a certain number (i.e. the top 25/50 tracks) or to filter the graph’s dataset (i.e. tracks that have had 3 or more plays), is there a way to do either of these?
Mohamed_Swella1
13 - Mars
13 - Mars
Hi @Tim_Reaper,
Welcome to Airtable Community! :grinning_face_with_big_eyes:
The way to do so is create a new Grid view, use the filter option to filter out whatever you do not need, use this view in your chart block.
BR,
Mo
Mohamed_Swella1
13 - Mars
13 - Mars
Hi @Tim_Reaper,
BR,
Mo
That worked perfectly, many thanks @Mohamed_Swellam
