Need help with Character Count Formula
1840 2
Joe_Spur
Goal: Calculate Character count limits for ppc ad sheet.
Character Count field is the number of words in the copy for that ad
Character Limit is the number of words allowed in the ad
IF({Character Count} < {Character Limit}, “ :white_check_mark: PASS”) IF({Character Count} = {Character Limit}, “ :white_check_mark: PASS”) IF({Character Count} > {Character Limit}, “ :x: FAIL”)
Please help! Thanks in advance
IF() statements have an implicit “else” portion as a final clause. You can also check for “less than or equal to.” So your formula should be
    {Character Count} <= {Character Limit},
    "✅PASS",
    "❌FAIL"
Joe_Spur
Thank you so much! Really appreciate your help with this…
