Searching a base which has a field zip code for example
2210 6
Matteo_Pota
Greetings! what is most efficient way to query a base for zip codes >= 12499 and <=14999 for example? Thanks
2 Solutions
18 - Pluto
18 - Pluto
Make sure that your zip code field is set to be a number field (instead of a text field).
Then, you can use the “Filter” button in the toolbar to create 2 filter criteria.
Filter #1:
Zip Code >= 12499
Filter #2:
AND Zip Code <=14999
Hope this helps! If this answers your question, could you please mark this comment as the solution to your question? This will help other people who have a similar question. :slightly_smiling_face:
Matteo_Pota
You are the best! Thank you so very much. I see solution is already checked!
6 Replies 6
18 - Pluto
18 - Pluto
Filter #1:
Zip Code >= 12499
Filter #2:
Thank you so much for your response. My zip code field is currently a single line text…can I change it to a number field as you suggest without losing data? I have 2652 records?
Yes, you can change it without losing data.
Matteo_Pota
Matteo_Pota
Sorry…# integer or decimal?
Choose integer for the formatting.
