Searching whole base for duplicates
691 1
Katie_James1
How can I search for duplicates across a whole base, not just within one table?
Radhe-iad
I would suggest using an external too like Make or Zapier that you can instruct to search for both values and if there is a match you can update a variable or something that keeps track of it.
