Simple question about data linking between tables
1410 2
Mathieu_Quiniou
Hi !
I’m searching since days the solution on the forum, i just can’t find it, but it might be really easy !
I have two tables, in one of them i have all the informations i need, and in the other i would like to have a general view of my data, and organize it.
For example, i have a column with a single select, and i would like to retrieve in the other table, only the records that have the “Yes” option.
In the second table where i want to retrieve the data, i already created a link to the first table, to count afterwards, but it doesn’t work … Any idea ?
In general, i want to retrieve certain data from a table depending on specific criteria, to another one.
Zollie
10 - Mercury
10 - Mercury
Since you’re using linked records, you can use some combination of rollups, lookups and/or formulas depending on what you’re trying to do.
Here’s the single select example you described:
Table 1
Name (Single Line Text)
Orange
Apple
Banana
Yes No or Maybe? (Single Select)
“Yes”
“No”
“Maybe”
Yes Value (Formula)
“Yes”
Formula: IF( {Single Select} = "Yes", "Yes", "" )
Table 2
Fruits (Linked Records)
Orange, Apple, Banana
Fruits with “Yes” (Rollup)
1
Rollup Settings: Table 1 > Yes Value (formula)
Rollup Formula: COUNTA(values)
Zollie
10 - Mercury
10 - Mercury
Table 1
Orange
Apple
Banana
“Yes”
“No”
“Maybe”
Yes Value (Formula)
“Yes”
Table 2
1
Mathieu_Quiniou
Thanks a lot, it works !
