Timeline Block and Record Stacking
Topic Labels: Extensions
1822 1
Didn’t records in a Timeline block used to stack to avoid overlapping like this?
CleanShot 2020-07-11 at 00.52.48@2x
It’s been a while since I used the Timeline block, but I swear when I used it before, the records stacked so that you could actually read the labels when they were condensed like this. What happened? Am I doing something wrong in the way I set it up that is causing them to stay on the same plane?
Zach_Manzi
Hi @Jeremy_Oglesby,
Thanks for reaching out about this! You should be seeing a message from us soon––we’re looking into this and will also respond here when we have an answer on what’s going on here.
