Timeline Block - Different color for each record
2838 4
Kyle_Allen
I created a timeline block for a table but I can’t figure out how to get each record to be a different color. Can someone help me with this please?
4 Replies 4
Just checked, the color depends on the color of a Single Select values. Do you have created one and applied colors to the options?
Thank you! I will need to change the field type for the first field. I really appreciate it.
how do you change the color of single select values?
In the field configuration, every option has a dropdown for the color, next to the name.
