I’m using integromat to automate some data from google sheets to airtable.
In this automation flow, I’m using ({record ID} = ‘string’) formula to match the g sheet cell with the airtable record id. For the most part this worked just fine until it came across a record that also had ’ in the record. This, I presume caused an error in the formula to not match the string as it stopped after the ’ character thinking that was the end of the string.
Is there an escape character I can use in this formula to solve this issue? Or is this something I have to solve in the google sheet for the matching strings?
