Apr 13, 2020 01:13 PM
My formula is MONTH({Trial Date})-1
I want that to then return a month name instead of a number.
I’ve been trying to figure out the DATETIME_FORMAT to do it, but I cant get it.
Apr 13, 2020 04:43 PM
To replace a month number with a month name, use a SWITCH statement as demonstrated below.
How it Works
SWITCH(
some logic that returns a value,
if the value is this,
return this,
if it's this,
return this,
etc.
I think you’re trying to describe ‘the month before the trial date?’ If so, run this:
SWITCH(MONTH({Trial Date})-1,0,"January",1,"February",2,"March",3,"April",4,"May",5,"June",6,"July",7,"August",8,"September",9,"October",10,"November",11,"December")
Apr 14, 2020 06:19 AM
THANK YOU! This worked perfectly! I’m not familiar with SWITCH.
Thank you for your help on this!
