Filtered Calendar View Using a Multiselect Field
Topic Labels: Base design
1060 0
EMHEP
I have created a base in airtable. I have a multiselect column called "Attendees". One of the options in this column is "Product". I am currently trying to create a calendar view in airtable that is specific to the Product team. To do so, I have created a filter that says "Where "Attendees" has any of "Product"". However the records that have Product tagged do not appear on the calendar. How do I get the records tagged with "Product" under the multiselect column "Attendees" to appear on the calendar? I do not have the option to choose "contains" when I set up the filter.
0 Replies 0
