Live base design webinars starting April 6
Topic Labels: Base design
497 0
Jason
Airtable Employee
Airtable Employee
Untitled_Artwork 7
If you’re not sure how to get started with designing your base, our resident Airtable experts are currently leading 45-minute trainings for the use cases listed below. Each training starts from scratch and walks you through the motions of building a ready-to-use workflow within your base.
If you’re interested, just fill out the form and select your preferred time slot — no Airtable experience is required to join!
0 Replies 0
