Save the date! Join us on October 16 for our Product Ops launch event. Register here.
Jul 22, 2024 11:55 AM
I would like to know if there is a way to automatically use the same colors for single select and multi select options for cohesion and ease of viewing.
For example:
1. If I have a survey, all Yes/No questions will automatically make 'Yes' chips green and 'No' chips red.
2. If I have several multi-select questions with answer options 'Strongly agree, Agree, Disagree, Strongly disagree'
I can Strongly agree - color green, Agree - pale green, Disagree - orange, Strongly disagree - Red
Jul 22, 2024 04:26 PM
No way to do this I don't think. Your best bet is to duplicate each field once you've set it to the way you want it. It's sort of like a "template" field you duplicate.
Jul 23, 2024 02:37 AM
We're able to update the single select and multi select field option colors by scripting, so you could write a script that you run for every single/multi select field you create: https://airtable.com/developers/scripting/api/field#update-options-async
Jul 25, 2024 02:01 PM
you can use it to transfer colors and options from existing fields to new.
Adjust line 1. Ignore red linter mark.
const [T1,F1,T2,F2]=['Source_Table','Colored_Select','Destination_Table','New_Select_Field'];
await base.getTable(T2).getField(F2).updateOptionsAsync({'choices':
[...base.getTable(T2).getField(F2).options.choices,...(base.getTable(T1).
getField(F1).options.choices.map( ({id,...rest})=>({...rest}) ))]
