Separating Items in a Cell that is linked to JIRA
  • March 9, 2023
  • 16 views
I have limited knowledge of AirTable and JIRA integration and I am trying to view each row in their own respective "Sprints," however, some issues within each sprint overlap. How can I separate the additional sprints from each row and have issues move over from one issue to the next if not completed in the current sprint?
I can provide additional information if needed.
Forum|alt.badge.img+31
Hm if this is just about viewing it, then you could try using a List view.  This would need you to have a "Sprints" table though, which should be easy enough to do
If you specifically need it as a record so that you can key in data specific to that issue during that sprint, then you'll need to create a junction table of some sort where you end up with the following:
And you could create an automation with the repeating groups functionality that would help you with this
