Timeline View : alt-click-shift-drag to duplicate record in same swimlane
Topic Labels: Views
480 0
Kirk_Fuson
While working in a Timeline view, is there a way to select a record and alt-click-shift drag to duplicate? Moving a record between swimlanes is a convenient action. Duplicating a record by clicking the three dots to the right of "expand" and choosing duplicate is convenient action. It would be really handy to just alt-click-shift-drag a record or records to duplicate it in the same swimlane or another swimlane.
Certainly, I'm not the only user who might find this helpful.
0 Replies 0
