USING BUTTONS
Topic Labels: Base design
299 1
Jorge1
Hi:
I designed a base that has a button in each record in order to print records fields using the page designer extension.
I am using that same base in an interfase, but in the interfase the button does not work, it is not clikable.
What do I need to do in order to be able to print individual records from the interfase?
Unfortunately I do not think this functionality exists and buttons cannot open extensions at this point
