Aug 30, 2022 03:21 AM
Hi all,
I have a problem with a project i am carrying out.
I have a table A. with a X record which is linked to a field Y in table B and field Z in table C.
After I have a table D. This records are linked to a field in table A.
So , records in table D , are linked indirectly to table B and C.
Now i have a table E, which is an input record to control hours.
When I add a record with a field linked to table D, I can add a field with a lookup function, to show the linked field in table A.
My problem is that i need to fill automatically as well, fields Y and Z which are linked to field in table A.
Some idea how to perform this task?
Many thanks in advance
Solved! Go to Solution.
Aug 30, 2022 11:01 AM
The trigger is incorrect. It should be “When Record Matches Condition” and the condition should be 1 is not empty and 5 is empty
Aug 30, 2022 07:42 AM
Hi @Jose_C
You can do that by getting the Record Id from Table B & C to Table A, then using those record IDs trigger an automation to update those records based on data from Table E
Aug 30, 2022 10:33 AM
Many thanks for your help, but i can´t do it work with your approach.
I am going to be more explicit in order to receive your help.
I select from [1]. a linked field, lets say HU-3/PRD43-1
Automatically with a lookup i get [2] and [3] and [4]
This field [4]. needs to be “copied” in another linked field i [5] in the same record
Thats the point… i am trying what you say
but , im stucked.
Nothing works.
If you can give me a solution, I will be very grateful
Aug 30, 2022 10:45 AM
This is very easy actually :slightly_smiling_face:
You just need to input the correct values in the above fields.
Record ID is the Record ID from the test step and the field you need to update “Prefil comprador” should have a dynamic value of “Pais name”
Aug 30, 2022 10:59 AM
I made a mistake
[5] is pais
but then i try this
and then I input [1] that automatically puts [4]
but not [5]
it is still empty…
automation is not working, and i dont know why
:frowning:
Aug 30, 2022 11:11 AM
Many thanks,
it works like a charm!!!
Aug 30, 2022 11:17 AM
The only problem is that changes in [1]. as it is a linked record from other table, is not reflecting in [5]
it is like [5] is static after the automation.
Some idea?
Aug 30, 2022 12:10 PM
You mean that 5 can change? In this case we need to think of another trigger. Maybe when a field is modified and make it watch 1?
Aug 30, 2022 12:23 PM
It not very usual, so i am going to remain with your solution.
Many thanks
Aug 31, 2022 10:15 AM
Anytime :slightly_smiling_face:
Please mark is as Solution
