Formula help
141 2
Donna
Using the formula below I have an ERROR value issue when there is no date value available for {last deal stage change}. Can anyone advise how I would alter this to just leave a blank space or "no data" where there is no date value available in the date field column?
I need to use the datetime format to tidy up and remove the timestamp
TRIM({Status symbol} & " | " & {Pipeline} & " | " & "Stage last changed: " & DATETIME_FORMAT({last deal stage change},'DD/MM/YY') & " | " & {Deal Stage})
Ben_Young1
10 - Mercury
10 - Mercury
Hey @Donna,
Here are two options:
If you want it to just skip it entirely if the field is blank, then you can use this:
TRIM(
        DATETIME_FORMAT(
            {last deal stage change}, 'DD/MM/YY'
If you want it to return "No Data", then you could use this:
TRIM(
        DATETIME_FORMAT(
        "No Data"
Ben_Young1
10 - Mercury
10 - Mercury
Hey @Donna,
TRIM(
        DATETIME_FORMAT(
TRIM(
        DATETIME_FORMAT(
        "No Data"
Thank you @Ben_Young1  all fixed. I really appreciate your help with this!
I'm still finding my way with formulas and nesting 🙂
