Airtable Cobuilder is here! Learn more about our new no-code app creation feature, powered by AI on the Airtable Academy
Mar 06, 2024 09:39 AM
Can anyone tell me where I'm going wrong with this formula?
Or suggest another way to achieve it - I've tried a few IF options too but can't get that to work either.
For context, I'm a literary agent and depending on the type of deal I do I either take 15% or 10% commission. Where I take 10% a co-agent will have also taken 10% but that's not necessary for me to track, other than that when I'm working out the author's overall income I need to make sure I know they didn't get it (hence trying to take away my commission twice in those instances here).
The closest I got to it working (ie, it actually ran something instead of refusing to save because of an error), I got words back instead of numbers and what I need is numbers.
Solved! Go to Solution.
Mar 06, 2024 06:18 PM
Try removing the trailing comma in your formula:
SWITCH(
{HS-LA %},
"15%", ({GBP Amount}-{HS-LA Commission}),
"10%", ({GBP Amount}-{HS-LA Commission}-{HS-LA Commission})
SWITCH(
{HS-LA %},
Mar 07, 2024 02:40 AM
Ah! Thank you!
