Help with a formula not recognizing when field is blank
2148 2
bmcad1116
Can someone help me figure out why the ‘else’ part of my IF statement isn’t working?
I'm trying to create a friendly date/time/timezone field IF a certain date field is not blank. That part is working. But if the date field is blank, I want it to put “N/A” in the new field. That part is returning an error.
Here is my formula.
 {REQUESTED GO LIVE DATE} !=BLANK(),
  DATETIME_FORMAT({REQUESTED GO LIVE DATE}, 'M/D/YY') & " at " & {REQUESTED GO LIVE TIME} & " " & {GO LIVE TIME ZONE}, "N/A"
I also tried it this way:
IF({REQUESTED GO LIVE DATE}=BLANK(),"N/A"
But neither formula is recognizing what to do if the REQUESTED GO LIVE DATE field is blank. Oddly, it is working when I remove the first part of the formula to only look for blank date field.
IF({REQUESTED GO LIVE DATE} = BLANK(),"N/A"
Attached is a screenshot of the results.
Alexey_Gusev
13 - Mars
13 - Mars
In short, you don't need to use BLANK() word, Just IF({Field}, [expression when Field not empty] , [output when Field is blank] ). The last can be omitted, default is blank, so IF ({Field} , [expression] ) also works.
Hey @bmcad1116
Try this formula:
TRIM(
        DATETIME_FORMAT(
            'M/D/YY'
        & IF(
            {REQUESTED GO LIVE TIME},
            ' at '
        AND(
        {REQUESTED GO LIVE TIME} & IF(
            ' ' & {GO LIVE TIME ZONE}
Alexey_Gusev
13 - Mars
13 - Mars
