Help with a Formula
478 1
ROIConsultants
Good Day,
I need assistance with a formula, I would like to count the status of registered learners for a specific project. I tried the Counta formula but the numbers does not add up correctly. It shows for example 2 learners registered against the project code, but none of the learners are registered yet, therefor should show 0?
COUNTA({Learner registration status},"Registered")
seferiannie
delete those empty lines which are auto-populated in the form / project. the formula is correct
