Jul 01, 2021 05:53 PM
I am in need of some guidance on a formula. I have two columns that I am comparing against each other - basically determining the dollar difference between the two and then the % difference that amounts to. Once that is figured out, I want to grade the resulting % as pass or fail, but I want to do it as a range. Here is an example:
A) Final Estimate: $10,000.00
B) Preliminary Estimate: $9,000.00
C) Difference in $: ($1,000.00)
D) Difference in %: (10%)
Here is where I need a formula:
IF the result of D is within a range of 10% under to 10% over the Final Estimate then the grade would be “Pass”. IF the result is either more than 10% below or over 10% above the Final Estimate, then the result is “Fail”. So I want to allow a spread of 10% each way off of matching the numbers as allowable.
Any help would be appreciated. Thanks!
Solved! Go to Solution.
Jul 01, 2021 06:48 PM
Hi Wayne. This might work…I haven’t tried it. It should get you close.
AND({Final Estimate},{Preliminary Estimate}),
ABS( ({Final Estimate}-{Preliminary Estimate})/{Final Estimate})<=0.1,
‘Pass’,
‘Fail’)
Good luck!
Jul 01, 2021 09:07 PM
Hi Chris,
Here is what I actually have for column names:
Estimate (LU) for the main estimate.
Calculated - ROM Amount for the preliminary estimate.
The column I am using for the formula is called Grade.
Here is what I did related to you solution: Not sure if I am doing something wrong, but it didn’t seem to return the values:
IF(AND({Estimate (LU)},{Calculated ROM}),IF(ABS({Estimate (LU)}-{Calculated ROM})/{Estimate (LU)})<=0.1,‘Pass’,‘Fail’))
AT says there is an error with my formula… did I miss something or write it wrong?
Thanks
Jul 02, 2021 04:35 AM
Hey Wayne. I think you missed a second open paren after “ABS”. Check my formula, there should be two, otherwise it looks good to me. Let me know if that works.
Jul 02, 2021 06:58 AM
That was it!! Thanks - never would have EVER got this one without your help!
