Help with Concatenate field with a condition
513 3
Ashley_Cain
Hi! I need to create a formula that concatenates the First Name and Last Name columns. I could do that part easily enough. But I also need it to look to see if there’s a value in the Preferred Name field and if that field has a value in it, to substitute that for the First Name.
Is this possible? How would I do this?
Here’s a screenshot, for reference:
Screenshot 2022-11-18 at 10.53.47 AM
3 Replies 3
Xavier_G_Sabate
Hi Ashley,
try something like this:
CONCATENATE(
		TRIM({Preferred Name})
		, {Preferred Name}
		, {First Name}
	, {Last Name}
This should do the work
That worked perfectly. Thank you so much!
you’re welcome Ashley
