Help with formula?
  • August 3, 2023
  • 18 views
Hi I got help with this a little while ago and it was perfect but now I want to add to it and anything I try does not work.
This is relating to an commissions payable per situation.
  {Booked By} = 2,
  {Points Paid} * 0.04
The above works however I want to add more situations -
IF booked by 0 points paid is 0.00
IF booked by 1 points paid is 0.03 OR
IF booked by 2  points paid is 0.04 OR
Thanks in advance.
Best answer by Sho
Hi @Bianca_Kearney ,
For simple conditional branching, the SWITCH function is easy to understand.
SWITCH({Booked By}, 2, {Points Paid}*0.04, 1, {Points Paid}*0.03, {Points Paid}*0 )
Forum|alt.badge.img+24
  • August 3, 2023
  • August 6, 2023
Thank you so much!
