Aug 02, 2019 02:06 PM
Hello AT Community
I’ve got a formula partially working but I’m having some difficulty tweaking it to just the right look.
Looking for numbers in the SAL field that result as a negative to show the emoji - so far so good. How do I make positive numbers in the ‘test’ field show as a percentage with only two numbers behind the decimal and with proper rounding up?
Thanks in advance for your brilliance!
Aug 02, 2019 05:25 PM
You can click formatting tab as in the following
It might not be possible the way I recommended because for formatting to work the result of formula should be number. In your case result is emoji or number.
Neal
Aug 02, 2019 06:17 PM
Check out the following base
It manipulates decimal number before and after decimal point.
Please note that this is initial version .
You need to check and modify formulas so that it works for all the possible numbers in your base.
Neal
Aug 02, 2019 08:08 PM
Thanks so much Neal, I don’t see where I can copy the base. I don’t get the formatting option because of the formula. I think the base was shared as view only, as I can’t see any of the formulas or copy. Appreciate your help.
Aug 02, 2019 09:10 PM
@CottageKeeper
Sorry Lisa,
Following link will get you as editor in the base .
Please let me know if you encounter any problems.
Thanks,
Neal
Aug 02, 2019 09:14 PM
@CottageKeeper
Lisa,
I was also able to change permission to you as editor.
No need to click above link to the base.
You are all set and you should be able to have copy base link as well as you should be able to see formulas.
Other users can click the following link to base and they will get editor access.
It will also have copy-base link to copy base.
Aug 14, 2019 11:17 AM
Thanks so much Neal, unfortunately when I click the formula, formula 2, formula 3, field 8, and field 9 I can’t see the customize field type option which would show me the formula you made. Would it be possible to change my permission to ‘creator’ so I can see the formula when I select the dropdown for each of these fields in the customize field type option?
Aug 14, 2019 12:32 PM
I have set you up as creator.
Other alternative for looking at formulas is to copy/duplicate base .
Neal
Aug 14, 2019 01:43 PM
Thanks Neal, for some reason I didn’t have the option to copy/duplicate the base, not sure why? I’ll look again, grateful for your help!
Aug 14, 2019 02:06 PM
Neal, you’re amazing! I have reviewed and but unfortunately, I’m still confused. I looked at my initial post and adjusted the wording I’m hoping it makes better sense?
Aug 14, 2019 02:58 PM
I have created field called “Lisa” and it uses single formula instead of using multiple formulas.It will help you to use formula without need of understanding dependent formulas.
Name of field I am using is called “decimal”. You need to replace “decimal” with your fieldname in your base.
Neal
Aug 15, 2019 07:05 AM
Thanks again Neal, I still can’t get it to work right, I’m using the SAL field in the formula where you used the decimal field.
Aug 15, 2019 08:39 AM
Formula expects field to be Decimal instead of currency.
At present your SAL is of type currency. Change its formatting to be Decimal.
i.e. Customize field SAL formatting to be
Decimal(1.0) with precision 1.00
Neal
Aug 15, 2019 01:03 PM
Thanks, Neal, unfortunately, that is not an option. I have to keep the SAL field as a dollar amount.
This is what I was able to do as a workaround. I can’t have the emoticon face populate for negative numbers in the SAL field - which what I was looking for. But until there is a better solution, I’ll have to stick with this:
I am grateful for your support in all of this!
Aug 15, 2019 02:03 PM
Try the following
Neal
