Help with nested if
571 3
Erica_Holleran
I can not get this formula to work.... is it completely wrong or am I missing parathesis?
IF({PMID}=“BathJR”,"Jason R",IF({PMID}=”BathSS”,“Stuart S",IF({PMID}=”BathBL”,“Brian L",IF({PMID}=”ODLBL”,“Brandon C",IF({PMID}=”WINBL”,“Evan V",IF({PMID}=”ODLJR,“Brandon C",IF({PMID}=”WINJR”,“Evan V"))))
3 Replies 3
I count 7 IFs, so you should have 7 closed parentheses at the end, not 4. Also, sometimes Airtable can get snippy about not have a closing ‘value if false’ at the end of a bunch of nested IFs. If adding the extra parentheses doesn’t work, you may need to add that at the end.
Having said that, this is a great candidate for a SWITCH instead of multiple nested IFs.
Erica_Holleran
SWITCH worked perfect - thank you!
Yay!
