Aug 29, 2020 10:36 AM
I’m looking for help writing a formula to show what pay a staff member has earned based on a variable.
I have hours worked (at 30 per hour for one role, and 25 for a different role), and trainings complete at 50 per session.
How do I write a formula that looks at the “role assigned select field” and calculates based on the correct rate of pay?
Thanks,
Solved! Go to Solution.
Aug 29, 2020 10:53 AM
Hi @Ryan_Anderson1 - you can do something like this:
IF({Role Field} = 'Role 1', {Hours field} * 30, {Hours field * 25})
and then to include the trainings you can extend this with:
IF({Role Field} = 'Role 1', {Hours field} * 30, {Hours field * 25}) + {trainings complete field} * 50
For 2 roles, an IF statement is fine. If you end up with more than this, you can move to SWITCH statement, which is often easier than multiple nested IFs
Aug 29, 2020 11:07 AM
Thank you! I’ll start there and see if I have any issues, thank you!
Aug 29, 2020 11:08 AM
This isn’t correct - should be:
{Hours field} * 25
