Need help changing formula to display "week of" month as a number rather than letter
1274 2
fordwitman
So I found a formula someone else made that does exactly what I need it to do.  I need to display the dates of certain events as "week of" so I can group the event by the week and see how many posts are made during the week.  The problem with the formula is it makes the "week of" appear as Apr 3, 2023, when I need it to say 04/03/2023.  The formula is:
DATETIME_FORMAT(DATEADD(Date,1-DATETIME_FORMAT(Date,'E'),'day'),'ll')
Can someone help me out?  Thanks!
(Field on the left is the date of event, field on right is the "week" formula)
BillH
9 - Sun
9 - Sun
If you change the 'll' to point 'l' you should get the result you need.
https://support.airtable.com/docs/supported-format-specifiers-for-datetime-format
BillH
9 - Sun
9 - Sun
Thank you so much!  Worked like a charm.
