Need help on IF formula
1788 3
JustineC
I want to create an IF formula but the result I get is not what I expected
Here is the formula: IF({Date effective de fin du cadrage (from Date effective de fin du cadrage)}<{Date estimée de fin du cadrage (from Date estimée de fin du cadrage)},"In time","Late")
I want to get: "In time" if the effective end date of the scoping is before the estimated end date of the scoping and I want to get "Late" if the effective end date of the scoping is after the estimated end date of the scoping
However, I'm getting "Late" whereas I should get 'In time".
Could you please help me? Thank you very much
3 Replies 3
Sho
11 - Venus
11 - Venus
Hi @JustineC,
Date and time comparisons require the use of a dedicated function.
IS_SAME(), IS_BEFORE(), IS_AFTER() and DATETIME_DIFF(). Read the reference for details.
Formula Field Reference - Overview | Airtable Support
For example, like this
  IS_AFTER(
    {Date effective de fin du cadrage (from Date effective de fin du cadrage)},
  "In time",
  "Late"
JustineC
Many thanks for your quick reply!! That works!
I have another question for you, I'm really bad at adding multiple formulas into one.
How could the one formula be with all those conditions:
No effective end date:
If today’s date is before estimated end date = in time
If today’s date is after estimated end date = late
Effective end date:
If effective end date is before estimated end date = in time
If effective end date is after estimated end date = late
Many thanks!
Sho
11 - Venus
11 - Venus
Formula syntax is easy once you learn the patterns.
If the field name is used as a condition, it can be used to determine if the field has a value.
In that case, like this.
    IS_AFTER(
    IS_AFTER(
      TODAY(),
  "In time",
  "Late"
