Question re using Substitute
196 3
MettaSong
I imported a financial report from PayPal. All of the Negative amounts in the "Amount" field use a "-" in front of the value. I want to create a new field that removes the "-" and just lists the value of the Amount field.
If the amount doesn't have the "-" symbol, I just want it to leave the record blank.
I tried using a substitute formula in the new field, but not sure how to get a blank value in the new field if the original amount value does not have a "-" sign.
SUBSTITUTE(Amount, "-", " ")
What would be the best way to do this? Thanks in advance.
2 Solutions
Hey @MettaSong
Did you try to use the ABS formula for that field. I recommend this because you actually want to have the absolute value from your negative number values.
This solution will work either your field is number either it is text.
Yours sincerely,
Dimitris Goudis
15 - Saturn
15 - Saturn
Utilizing Dimitris solution of using ABS, you could put it inside an `IF()` like so:
  Amount < 0,
  ABS(Amount)
3 Replies 3
Hey @MettaSong
Yours sincerely,
Dimitris Goudis
15 - Saturn
15 - Saturn
  Amount < 0,
  ABS(Amount)
MettaSong
Thank you @TheTimeSavingCo  & @Dimitris_Goudis - that is an elegant solution. I had never even considered the ABS formula. Perfect! I greatly appreciate your time and wisdom!
