Regex to split string into comma-separated tags
  • May 28, 2022
  • 119 views
Forum|alt.badge.img+11
My datafile has a field with multiple tags that are joined like this:
TagoneTagtwoTagthree
Is there a formula possible, with help of regex, to put a comma between all lowercaseUppercase instances to seperate them?
Yep.
REGEX_REPLACE(Tags, "([a-z])([A-Z])", "$1,$2" )
Kamille_Parks11
Forum|alt.badge.img+27
Yep.
Rupert_Hoffsch1
@Kamille_Parks If you don’t mind, what you point me to a support article in which the use of variables ($1/$2 in your case for the capture groups) is described? I tried to find it just now and couldn’t… Thank you!
Kamille_Parks11
its not really documented, just noted that putting parentheses around a portion of a query creates a “numbered capturing group”. from there its extrapolating the relative order of each group you create preceded by a $
Rupert_Hoffsch1
Thank you! (just adding characters to reach 20 characters… ;))
