Substitution formula help
  • January 27, 2021
  • 32 views
Hey guys,
I’m hoping someone can help me - I’m such a beginner at formulas!
I am creating a table to hold all my email campaign data. At the moment I’m logging all my data fields.
What I need is a formula that will take a field make like ‘full name’ and turn it into a personalization tag, so the space needs to disappear, it needs to be in caps and I need a % sign at each end, so it would end up looking like this: %FULLNAME%.
I don’t have the very first clue how to go about this so any help you can give me would be pathetically gratefully received.
Thanks in advance!
Katie x
  • January 27, 2021
Hi there! Try this…
IF({Field}, UPPER("%" & SUBSTITUTE({Field}, " ", "") & "%"))
Hope that helps!
  • January 27, 2021
HOLY GUACAMOLE
That’s amazing, thank you so much.
Can I trouble you to show me how I’d adjust that formula so that instead f getting rid of the spaces, it adds an underscore instead? It would be very helpful for my table, and I think it would help me to see two different formulae and see how they change.
No worries if you don’t have time though, you’ve already been amazingly helpful <3
Forum|alt.badge.img+10
HOLY GUACAMOLE
That would be
IF({Field}, UPPER("%" & SUBSTITUTE({Field}, " ", “_”) & “%”))
