Oct 19, 2020 04:48 PM
Hi All, I’d like to create a unique number for a record based on the year and week. So for example, I have a date field which I use as YEAR(Date)&" - "&WEEKNUM(Date). So if the date was today this would give me an output of 2020 - 43.
Now, I want to add a counting number for each record with a date in that week in order of when the record was created. So the first record created with a date in that week would be “2020 - 43 - 1” and the second record created would be “2020 - 43 - 2” and so on and so forth. But when the week changes to the next week I want the counting number to start again, so it would then go “2020 - 44 - 1”, “2020 - 44 - 2” and so on.
I just don’t know how to do this and would appreciate any help thanks.
Solved! Go to Solution.
Oct 19, 2020 05:37 PM
You could do this for all records going forward using an automation with a script action step:
YEAR - WEEKNUM
.const inputConfig = input.config()
const weekNum = inputConfig.weekNum
const table = base.getTable("Table Name")
const query = await table.selectRecordsAsync()
const records = query.records.filter(x => {
return x.getCellValue("Name of formula field") === weekNum
const position = records.length
output.set("position", position)
[Record (Step 1: Trigger) ... {Formula Field}]
- [Data (Step 2: Run a script) position]
YEAR - WEEKNUM
Oct 20, 2020 12:05 AM
Thanks so much! I got this working.
