Using Concatenate with Multi-selects Leaving an extra comma...?
775 3
epicmike2835
If I use this formula:
IF({Whole-Body Conditions}!=BLANK(), {Whole-Body Conditions}, "") &
IF({Body: Left Foot}!=BLANK(),
CONCATENATE(", ", {Body: Left Foot}), "")
I get this result when {Body: Left Foot} is NOT empty, WHICH IS WHAT I WANT:
But when {Body: Left Foot} is EMPTY, I get this result that has an extra COMMA:
When I take out the comma in the second IF statement, then there's no commas at all whether or not {Body: Left Foot} is empty.
So... what's up with that? Shouldn't it ONLY put the comma IF there's content in {Body: Left Foot}?
Sistema_Aotearo
9 - Sun
9 - Sun
Hmm not sure either. Try a formula like this:
{Whole-Body Conditions} &
IF(NOT(
   {Body: Left Foot}=""),
   ", ") & {Body: Left Foot}
Not sure if this is what you're looking for, but let me know!
Justin Ng
Programme Coordinator at Sistema Aotearoa
https://www.sistemaaotearoa.org.nz/
3 Replies 3
epicmike2835
It appears that it is caused by the referenced Multi-select field {Body: Left Foot} but I'm still not sure how that's possible if that field is blank it still produces a comma.
Sistema_Aotearo
9 - Sun
9 - Sun
IF(NOT(
Justin Ng
epicmike2835
Worked like a charm, thanks!
