Airtable Does not Scale Well
  • April 28, 2022
  • 107 views
Please correct me if I am wrong, but it appears to me that Airtable does not scale well at all with a maximum record limitation of just 100,000? Thus, it is not suitable for many businesses with a certain size.
What other software would you use in cases that you need to scale and more records?
I will still use Airtable personally and for certain things, but unfortunately I cannot use it business wide due to the limitations.
  • April 28, 2022
This is true. I typically recommend that my clients move on from Airtable to a true enterprise-level database software such as FileMaker, which has none of the limitations of Airtable because it has absolutely no limitations at all. FileMaker is an actual enterprise-level database language that is low-code, very user-friendly, and has zero limits. I don’t do FileMaker development anymore, but if you need me to refer you to some top FileMaker developers, feel free to contact me through my website at scottworld.com.
Ben_Young1
Forum|alt.badge.img+22
  • April 28, 2022
It’s not the craziest increase, but Airtable enterprise bases now have a maximum record count of 250k, up from 100k.
It went in around earlier this month.
  • April 28, 2022
Wow! Nobody told us about this record increase for enterprise! Thanks for pointing this out, @Ben.Young!
