Auto Numbering My Way
1357 0
skip_coblyn
I have a grouped table that is just the way I need to see it, and I’d like to assign an auto number column to sort the records in the order I want. When I do, the numbers that fill the column start where they will and go from there. How do I fix this?
Skip Coblyn
0 Replies 0
