πŸ†˜ Complicated formula help please
6342 29
Showing results forΒ
Search instead forΒ
Did you mean:Β
RnJ
8 - Airtable Astronomer
I have a scheduling base for Volunteers helping at Non-Profits. I am wondering if it is possible accomplish these with a formula?
I have attached a generic base to give you an idea of what i am looking for. I have entered the answers into the fields as an Example via text.
#1. Volunteering with -
If multiple volunteers are on the (same date, same location, same start time, same stop time), I would like column " :raising_hand_man: Volunteering with :raising_hand_man: " to show the names of each volunteer on the same detail.
#2. Double Booked -
If a volunteer is signed up for multiple details the same day I would like a column β€œ :eyes: Double Booked/Overlapping Shifts :eyes: ”, if they are double booked or have overlapping shifts.
#3. Relieving/Relieved by -
I would like two columns " :handshake: Relieving Volunteer :handshake: " & " :handshake: Relieved By Volunteer :handshake: " to list the names of those volunteers if applicable (ie. If one shift ends and another one starts. Shift one is 8:00am-10:00am, shift two is 10:00am-2:00pm, shift three is 2:00pm-4:00pm, etc.)
Thanks for any help you can provide!
29 Replies 29
RnJ
Awesome thanks Kamille! I am just starting to dig into learning to script :slightly_smiling_face:
P.S. Do you also do custom scripting for hire? If so, I may need to hire you for some other upcoming challenges I run into.
Thanks again
The answer 9/10 is no. Sometimes if there’s a fun use case within my capability I’ll consider it, but most times I do not. There are several highly talented consultants lurking in the forum that you can consider however.
RnJ
Well I do appreciate all the help, I just feel bad asking a ton of questions with really no compensation :slightly_smiling_face: They need some sort of tip button in the forum for the people so dedicated to help others :slightly_smiling_face:
RnJ
@Kamille_Parks Sorry, another question if you get time.
Would it be hard to add these to the original script?
For Double Booked/Overlapping Shifts:
If shift date & hours are the same display β€œDouble Booked” & If shift date & hours only overlap display β€œOverlap” otherwise β€œNo”
For Volunteering,:
If same shift does not have a volunteer assigned yet display β€œTBD” in place of Volunteer Name.
*this could be accomplished using a formula field IF(volunteer="",TBD,volunteer) but think would make sense to have in the script instead?
For Relieving Volunteer & Relieved By Volunteer:
Same idea - If same shift does not have a volunteer assigned yet display β€œTBD” in place of Volunteer Name.
Thanks again
For TBD you could replace the part of the script inside .updateRecordAsync() using this format:
'Name of Field': value ? value : 'TBD'
Replace value with whatever the script currently has there.
As for editing the double booking part: Yes its possible, no I don’t want to do it.
RnJ
I have been fine tuning this script for my needs and thought I would post the updates in case it can benefit anyone else.
@Kamille_Parks - Thanks again for getting me going on this. It has been fun to learn how scripting works and look forward to learning more.
This is the first time I have ever worked with scripting, so my modifications may have not been the best way, but they seem to work :slightly_smiling_face:
Changes Made:
  1. For Double Booked/Overlapping Shifts: If shift date & hours are the same display β€œDouble Booked” & If shift date & hours only overlap display β€œOverlap” otherwise β€œNo”
  2. For Volunteering: If same shift does not have a volunteer assigned yet display β€œTBD” in place of Volunteer Name. I also created another field so I could separate the volunteers assigned to same location/same hours & volunteers assigned to same location/overlapping hours.
  3. For Relieving Volunteer & Relieved By Volunteer: Same idea - If same shift does not have a volunteer assigned yet display β€œTBD” in place of Volunteer Name.
Code:
const scheduleT = base.getTable('Schedule')
const scheduleQ = await scheduleT.selectRecordsAsync()
const scheduleR = scheduleQ.records
const trigger = await input.recordAsync('Which schedule record do you want to gather info about?', scheduleT)
const triggerValues = {
    volunteer: trigger.getCellValueAsString('Volunteer'),
    start: new Date(trigger.getCellValue('Start')),
    stop: new Date(trigger.getCellValue('Stop')),
const shiftRecords = scheduleR.map(x => {return (
        volunteer: x.getCellValueAsString('Volunteer') ? x.getCellValueAsString('Volunteer'):'TBD',
        start: new Date(x.getCellValue('Start')),
        stop: new Date(x.getCellValue('Stop')),
const sameShiftRecordsexact = shiftRecords.filter(x => {
    return (
        ((triggerValues.start <= x.start && triggerValues.stop >= x.stop)) &&
        (x.location == triggerValues.location)
const sameShiftRecordsoverlap = shiftRecords.filter(x => {
    return (
        ((triggerValues.start > x.start && triggerValues.start < x.stop) || x.start > triggerValues.start && x.start < triggerValues.stop) &&
const isDoubleBooked = (shiftRecords.filter(x => {
    return (
        (x.id !== triggerValues.id) &&
        (x.volunteer == triggerValues.volunteer) &&
}).length > 0) ? '🚫 Double Booked' :
    return (
}).length > 0) ? '⚠ Overlap':
'βœ… No'
const prevShiftRecords = shiftRecords.filter(x => {
    return (x.stop.toISOString() == triggerValues.start.toISOString()&&
        (x.location == triggerValues.location))
const nextShiftRecords = shiftRecords.filter(x => {
    return (x.start.toISOString() == triggerValues.stop.toISOString()&&
output.table({
    ['Volunteer']: triggerValues.volunteer,
    ['Start']: triggerValues.start,
    ['Stop']: triggerValues.stop,
    ['Volnteering (same shift)']: Array(...(sameShiftRecordsexact.map(x => x.volunteer))).join(', '),
    ['Volnteering (overlapping shift)']: Array(...(sameShiftRecordsoverlap.map(x => x.volunteer))).join(', '),
    ['Double Booked?']: isDoubleBooked,
    ['Relieving']: Array(...(prevShiftRecords.map(x => x.volunteer))).join(', '),
    ['Relieved By']: Array(...(nextShiftRecords.map(x => x.volunteer))).join(', '),
await scheduleT.updateRecordAsync(triggerValues.id, {
    'EXAMPLE πŸ™‹β€β™‚οΈVolunteering (exact shifts) πŸ™‹β€β™‚οΈ': Array(...(sameShiftRecordsexact.map(x => x.volunteer))).join(', '),
    'EXAMPLE πŸ™‹β€β™‚οΈVolunteering with (overlapping shifts) πŸ™‹β€β™‚οΈ': Array(...(sameShiftRecordsoverlap.map(x => x.volunteer))).join(', '),
    'EXAMPLE πŸ‘€ Double Booked/Overlapping Shifts πŸ‘€': isDoubleBooked.toString(),
    'EXAMPLE 🀝Relieving Volunteer🀝': Array(...(prevShiftRecords.map(x => x.volunteer))).join(', '),
    'EXAMPLE 🀝Relieved By Volunteer🀝': Array(...(nextShiftRecords.map(x => x.volunteer))).join(', ')
RnJ
Ok, I just found a little hiccup in the code and am having a tough time finding a solution.
For my β€œsameShiftRecordsexact” it is pulling in data if the chosen shift is within another shift and not just exactly the same.
I thought this part
would just need
instead of
but that didn’t work :frowning: Any help is greatly appreciated :slightly_smiling_face:
Did you set both <= and >= to ==?
RnJ
Yeah, when I change them both to == it is not recognizing anything for the β€œsameShiftRecordsExact”.
((triggerValues.start == x.start && triggerValues.stop == x.stop)) &&
RnJ
Disregard. I finally figured it out :slightly_smiling_face: Had to change this block of code to with the β€œtoISOString”
Thanks again.
const sameShiftRecordsExact = shiftRecords.filter(x => {
return (x.start.toISOString() == triggerValues.start.toISOString()&&
    (x.stop.toISOString() == triggerValues.stop.toISOString()&&
