Create Project Tasks from templates
Topic Labels: Extensions
1280 1
Simon_Hayes
Hi all - somewhat daunted by the capabilities here … and so asking if someone can point me in the right direction.
My base table is straightforward - just a list of calendar events, grouped into courses.
What I want to do though is have something which allows me to populate new groups of events into that table based on some predefined rules associated with each course. For instance, if I were to setup a new course of type X, that might lead to three events being created in the table at +7, +21 +28 days from the start date of the course. Type Y might only have one event at +21 days from the start date etc. There are only a a small number of course types (<10) so needn’t be too complex. However, there are a lot of instances of courses being created.
Any advice? Thanks in advance.
This is a good place to start:
