Formula to sum points from other tables and group them by sprints
  • January 10, 2020
  • 8 views
I’m a long-time lurker and the answers in this forum helped me a number of times. However, I’m struggling finding a solution to the following problem:
Essentially I’m trying to extract a sum of points from one table and embed it in another table. Sounds simple, but please see details below:
There are 4 tables:
A, B, C and D
Each table has a list of records grouped by sprints with a point value allocated to each record.
I created a separate table E which is supposed to show the following:
  1. Group data by sprints
  2. For each sprint, have the allocated points for each table
| Sprint 1:     |
| Table         | Allocated points|
| A             | 150             |
| B             | 102             |
| C             | 25              |
Ideally, I’d have a formula that would show the following:
If {Table Name} = X THEN show sum of points for the sprint.
Ideally that would work for all tables by looking up the table name A B C and D.
Please let me know if there’s a way to do this or are there too many relationships here that are difficult to untangle?
Thanks,
Pepe
