Formular doesn't read as true() when date match with today()
  • April 26, 2022
  • 51 views
Hi all,
I have this formula IF(date={today()},TRUE(),FALSE())
when…
As you can see the column today() = true() doesn’t mark as true() even though they are the same.
thanks in advance
Forum|alt.badge.img+31
Hi @Sebastian_Castro, I can’t seem to replicate this, check out my attempt here in a readonly base: Base
Could you replicate this on a new base (so that there’s no private data on it) and share it so I could help you take a look at it?
  • April 26, 2022
Thnks @Adam_TheTimeSavingCo !
it´s read only for me. please be kind to let me update the base to check it.
  • April 26, 2022
When working with dates, I recommend using date functions for comparison. In this case, I recommend using something like
IS_SAME({date}, TODAY(), 'day')
You may also have timezone issues.
@Sebastian_Castro Yeap, I was thinking you’d duplicate the base into your own workspace, actually.
I’ve given you permissions for the base linked above, so you should be able to access the formulas now!
