Mar 07, 2017 08:08 AM
I am running Airtable on Windows 10. When I try to print to pdf, A4 size, the print to fit option appears not to work, i.e. fields are printed off the edge of the page. This happens with both the Foxit PDF printer and the PDFCreator printer. I ahve also tried Letter size, but same result.
Any thoughts?
Neil
Jul 16, 2017 11:13 AM
I had this problem as well. Was able to fix by selecting Settings on the Print Screen. Then selecting custom. A blue outline appears that allows the margins to be adjusted that prevent the records/fields from being split between 2 pages.
Jul 20, 2017 03:48 AM
Thanks Laura, I’ll give it a try.
Jul 20, 2017 04:03 AM
Unfortunately my printer (a Brother) doesn’t offer the option to change margins as part of the settings.
Hopefully your solution will help others though.
Neil
Jun 29, 2022 03:09 AM
I was having the same issue in my windows 10. I took assistance of professionals at VIP Signs and installed a dll file in my system.
