Jan 04, 2023 09:02 AM
Is there a way to show a counter when as new form is submitted?
So I am with a small UK charity and we are looking at setting up a new area but to do so we need 5 founding members and 100 people to say yes I am interested (see founding members and members counters on page below)
https://www.littlemiraclescharity.org.uk/our-branches/areas-coming-soon/st-ives-huntingdonshire
Is there a way to automatically update this? Our website is on a custom CMS so its not something I can do on wordpress I have a beautiful counter using the summary extension is there a way to have this as an iframe in order to update automatically? / Any other work around which I have not thought of - we are only a tiny charity so it really needs to be free though 😞
Any help would be amazing thanks in advance
Jan 09, 2023 01:16 AM
The easiest way would be to create a view that shows the data you want and use the iframe embed like you mentioned I reckon
Jan 09, 2023 01:29 AM
Thanks I have a view showing the data but any idea what section I could turn into an iframe? I have used the count as an extension but I cannot make that into an iframe that I can see?
Jan 09, 2023 01:45 AM
Ah I was just thinking about using a view as that comes with the embed option
I don't think you can use the dashboard with extensions as an iframe I'm afraid
