How to Add 1 Emoji for Each Checkbox that is Checked
  • February 26, 2020
  • 46 views
I have 10 checkboxes in my table. Each checkbox corresponds with a task that needs to be completed.
I’d like to build a formal that shows an emoji each time another checkbox is checked.
For example, if you’ve checked 4 boxes, there would be :white_check_mark: :white_check_mark: :white_check_mark: :white_check_mark: . Or, if you’ve checked 10 boxes, there would be :white_check_mark: :white_check_mark: :white_check_mark: :white_check_mark: :white_check_mark: :white_check_mark: :white_check_mark: :white_check_mark: :white_check_mark: :white_check_mark: .
Thanks in advance.
Best answer by Jeremy_Oglesby
Hi @RJ_Martino.
You’d have to check the state of each checkbox field by name, and then output your emoji based on the state. So something like this:
IF({Checkbox Field 1}, "✅") &
IF({Checkbox Field 2}, "✅") &
IF({Checkbox Field 3}, "✅") &
etc...
  • February 26, 2020
Hi @RJ_Martino.
etc...
  • February 26, 2020
Hi @RJ_Martino.
etc...
Great Stuff! Thanks for the help!
  • February 26, 2020
The formula from @Jeremy_Oglesby is a fine suggestion. However, it can be a bit difficult to see the difference between 9 and 10 check box emoji at a glance.
Another method would be to use a formula field count the number of check boxes and then use other formulas based on that.
Create a {Num Tasks Done} formula field that counts the number of check boxes. Notice that it is very similar to Jeremy’s. However, you can directly add the check boxes together. If a box is checked, its value is 1; if unchecked, its value is 0.
{Checkbox Field 1} + {Checkbox Field 2} + {Checkbox Field 3} ...
Then you can generate your emoji field with the formula
REPT("✅", {Num Tasks Done})
You can also create a formula to show the status:
IF({Num Tasks Done} = 0,
  "Not started",
  IF({Num Tasks Done} < 10,
    "In Progress",
    "Done"
Or a formula to show percent done (select percent as the format for the field):
{Num Tasks Done} / 10
