Is it possible to have a customised right click menu?
524 2
Adrian_Peyton
Hi, is it possible to add customised actions onto the right-click menu on Airtable?
For example, one of my columns has email addresses listed. I would love to be able to right click and hit an option like ‘Find on HubSpot’, which would just create the search query URL with the email address in question in a new tab to save me having to copy and paste a lot through the day.
Currently it has options for Insert, Expand, etc…
No, that isn’t possible. The closest thing would be having one (or more) Button fields added to the table that are configured to perform a particular action for the selected record.
7Uq1InHbc
I would love being able to run scripts from the right click menu instead of buttons in columns.  I have two many columns and it becomes hard to find the button I need.
