Is there a way to merge two tables?
  • August 13, 2019
  • 34 views
I am new to Airtable and have taken over a format that someone else started.
There were several pieces left out from the master table, which were, in the interim, documented on an excel sheet.
I was able to import as a new table, however the information needs to be added to the “Master”.
I couldn’t find a way to import the excel to the existing table, it only let me add it as a new one.
Is there a way to merge the two tables?
Kamille_Parks11
Forum|alt.badge.img+27
Assuming all the columns are in the same order, couldn’t you just copy the content of the new table and place it at the end of the other?
  • August 14, 2019
I tried that, (thinking maybe it would be somewhat like you do in excel), however, I am either missing something or it’s not a supported function. When I copy the cells it doesn’t let me “paste” them, it tries to put all the cells in one cell.
Kamille_Parks11
You could import the table, then copy those new rows to your existing table, thrn delete the imported table.
