merge problem - field not available
1791 3
kharpbrown
I'm trying to merge a CSV but the field that I need to map to is not available to select. I can't select the field I need as the merge field. It is not one of the options in the "choose a field" drop down.
Databaser
12 - Earth
12 - Earth
An autonumber field is automatically generated and can't be edited. That's why you can't merge existing data with it.
3 Replies 3
Hi @kharpbrown
What field type is that not available field? And the one that you're trying to merge?
kharpbrown
The field that is not available is a unique number. I'm trying to merge geotagging data.
Databaser
12 - Earth
12 - Earth
