Jun 25, 2022 02:12 PM
Hi All.
I found the following script code for sending a webhook from Airtable to Make but the input.config() in the first line demands an argument.
anyone knows why?
Jesper
let inputConfig = input.config();
let recordID = inputConfig.inputRecord;
console.log(recordID);
let url=‘https://hook.eu1.make.com/7emn6wadgl4bn494kgibfvtop3lf4h6s’
console.log(url);
let request= url.concat(‘?recordID=’,recordID)
console.log(request);
await fetch(request);
Jun 25, 2022 06:06 PM
Are you writing a script using the Scripting Extension/App or an automation?
The code looks like code for an automation script. If you want to run the script from a button you don’t need to use input.config()
to get the triggering record. Instead, use await input.recordAsync()
with the appropriate parameters.
Jun 26, 2022 02:06 AM
Hi again Kuovonne :winking_face:
Thank again fro taking the time.
I’m just trying to get an id from Airtable to Make and I don’t understand how it can be so hard :winking_face:
The first version should be a script called from a button. When I changed the input to a array it now came up with this error.
TypeError: URL is not valid or contains user credentials.
at fetch
at asyncFunctionResume
at promiseReactionJobWithoutPromise
Here is the code
// Get the airtabel webhook URL
let webhook = ‘https://hook.eu1.make.com/7emn6wadgl4bn494kgibfvtop3lf4h6s’
// Airtable script button name.
let actionDescription = ‘Sending images to processing’
let tableName = ‘MakeTestTable’
let fieldsToSend = [‘Brand2’]
let table = base.getTable(tableName);
let record = await input.recordAsync(actionDescription, table);
let queryParams = ‘/?id=$(record.id)’
if(fieldsToSend.length > 0){
function buildParams(fieldName) {
let fieldValue = record.getCellValueAsString(fieldName)
queryParams += ‘&${encodeURIComponent(fieldName)}=${encodeURIComponent(fieldValue)}’
fieldsToSend.forEach(buildParams);
const returnedpayload = await fetch(‘${webhook}${queryParams}’);
var payloadResponse = await returnedpayload.json()
let result = payloadResponse.result;
output.text(result)
Can you find the error?
Thanks / Jesper
Jun 26, 2022 06:22 AM
Nope. But it is also really hard to read your code because the forum is messing with the display of your code. When you include code in a post it is helpful to use the code formatting
button at the top of the editor.
You could also try using remoteFetchAsync
Instead of fetch
. See this documentation page for more info.
Jun 27, 2022 01:00 AM
let webhook = 'https://hook.eu1.make.com/uiob4x9vxuob2np2wwifebvlqfqenae4';
let actionDescription = 'Sending images to processing';
let tableName = 'Make test table'
let fieldsToSend = 'Brand 2'
let record = await input.recordAsync(actionDescription,table);
let queryParams = '/?id=$(record.id)'
queryParams += '&${encodeURIComponent(fieldName)}=${encodeURIComponent(fieldValue)}'
const returnedpayload = await fetch('${webhook}${queryParams}');
output.text(result)
Jun 27, 2022 01:06 AM
let url='https://hook.eu1.make.com/7emn6wadgl4bn494kgibfvtop3lf4h6s'
console.log(url);
let request= url.concat('?recordID=',recordID)
Jun 27, 2022 01:08 AM
Hi Kuovonne.
I’ve now sent you the two versions I’m trying to get working. Does that help ?
Hope you can find the problem.
Jesper
Jun 27, 2022 06:53 AM
It looks like your fieldsToSend
variable got turned back into a text string, instead of an array.
You also didn’t try remoteFetchAsync
If those things don’t do the trick, try posting screen shots of the error messages as well. I may not have time to further troubleshoot for you, but someone else might be able to.
Jun 28, 2022 12:23 AM
Ok Kuovonne but thanks a lot for the effort. Great of you to take the time. :winking_face:
