Right-click context menu overlap
529 1
Jeongyong_Kim
I’m using Naver Whale which is a Chromium-based web browser.
If I right-click on the table, the menu for the AirTable and the context menu for the web browser overlap. (The web browser menu covers the AirTable menu so that the AirTable menu is invisible.)
It does not happen in other browsers such as Chrome, Microsoft Edge, or Firefox.
If I want to use the AirTable menu, I should press the Esc key once to remove the web browser menu.
Is there a fix for this problem?
I recommend contacting support with a screen recording showing the behavior.
