Rollup formula problem
  • July 26, 2017
  • 45 views
I’m a self employed sales manager. I use Airtable to organise my seminars and contacts. In the Contact tab i have a row called Status. This is a dropdown menu with the options Succes, Lost, No contact.
I want to count in my seminar tab how many leads are a Succes.
What formula do i use?
Rollup: Contacts
Field: Status
Formula: ?
Thanks in advance!
Giovanni
  • July 27, 2017
Do you need this as a column for something? You can accomplish this using a column summary if you make a view that groups by Status.
  • July 27, 2017
(I assume you mean that in your Contact table there is a field [or column] called ‘Status’, which is a single select field with three options.)
In your Contacts table, create a new field called ‘Success’. Make it a formula field with this formula:
IF(Status = "Success","Y","")
In the Seminar table, create a rollup field called ‘TotalSuccesses’ with this configuration:
Table to summarize: Contact
Field to roll up: Success
Aggregation function: COUNTA(values)
That will give you a count of successful contacts resulting from each seminar.
This worked, thank you!
