Simple point system
Topic Labels: Automations Data Formulas
240 3
Romer
Hello, hope you are all doing well.
Need some help giving points to each participant per race result, would like to create a field on the same table with a formula that does that automatically.
The point system is basically the reverse order of the number of participants, ea: 1st place gets the total number of participants in points, the 2nd place gets one less, and so on, with last place getting 1 point
Here is the condition, only the "Pos" with numbers will get assign the points. Positions that have a DNF or DNS will get just 1 point
Here is the table:
Any help will be grateful, my brain is toast for the night, trying all kinds of ways.
This might be super simple for someone out there 😆
Thank you!
3 Replies 3
Hm so there are multiple races, right?  If so, I think you're going to need:
1. Races: table where each record represents one race
2. People: table where each record represents one person
Let's call your main table "Data"
You'd then link everything up accordingly, which would allow you to create a Count field in the Races table that'll give you the total number of participants for that race.  You could then use a lookup to pull that Count field into the Data table, and you'd use a formula that would help you output the points for each person based on:
1. Their position in the race
2. The total number of participants in that race
Once you output those points, you can create a rollup field in People on that new points field, which would give you each persons total from all their races
Is it correct that number of participants 11 here? And Pos1 gets 11 pts, Pos2=10 pts, Pos#6 gets 6 points, the rest (Pos 7-11) are 1 pts.
Your formula will be
1+IF(VALUE(Pos),11-VALUE(Pos))
if you have different total number each race, to count total, you need to link and do the stuff according to @TheTimeSavingCo  instructions
Romer
Thank you guys, will get working on this 😀@Alexey_Gusev already applied that formula, thank you man. @TheTimeSavingCo  will work on those tables tonight. Thank you all again
