Jan 23, 2019 07:24 AM
I’m still relatively new to Airtable and the advanced functions available. Have experimented with several of the examples available.
Would like to use a CRM that has mass emailing capability. From what I’ve read, that could be feasible with something like Mailchimp’s API and using Zapier.
Also, I’ve looked at HubSpot the free version which supports up to 1 million contacts as a CRM.
Does Airtable have similar ability to support that many contacts with upgrading?
Jan 23, 2019 01:38 PM
If you store 1 contact per Record, your limit is the Records limits for every plan: https://airtable.com/pricing
Also, the most common is to store other kind of information: Companies, Interactions, Sales, etc., so you’ll get to the limit with less Contacts stored.
Jan 23, 2019 09:42 PM
Some great templates have already been completed for you in the AT “Templates” section: Redirect Notice
Having said that hubspot is a great CRM product, even at it’s free level.
Jan 25, 2019 01:38 AM
If you go Pro, you could simply use the SendGrid block
